Evgeniy V
- 2 Ноя 2009
- 191
- 0
- Гена
Вот такая литровая штукенция c полезной нагрузкой - 335.6 кг .... Ваши мысли господа
ENGINE DISPLACEMENT (CC) 951
ENGINE TYPE V-Twin, SOHC, 4-stroke, 4-valve
FUEL SYSTEM Electronic Fuel Injection
COOLING SYSTEM Liquid
TRANSMISSION/FINAL DRIVE Duramatic CVT P/R/N/L/H; Shaft
DRIVE SYSTEM Electric 2/4 WD w/ 4WD Lock
SUSPENSION TRAVEL FRONT (IN./CM) 17/43.2
SUSPENSION TRAVEL REAR (IN./CM) 18/45.7
GROUND CLEARANCE (IN./CM) 13/33
SUSPENSION TYPE – FRONT Double A-Arm
(compression adjustment & reservoir)
SUSPENSION TYPE – REAR 5-Link Trailing Arm,
FRONT/REAR BRAKES 4 Wheel Hydraulic Disc
PARKING BRAKE Park in Transmission
TIRE FRONT 26x9R-14
TIRE REAR 26x11R-14
WHEELS Aluminum
FUEL CAPACITY (GAL./LITERS) 8.8/33.3
BED BOX DIMENSIONS (IN./CM LxWxH) 35.8 x 21 x 8.4 in.
90.9 x 53.3 x 21.3 cm
BOX CAPACITY (LBS./KG) 300/136.1
PAYLOAD CAPACITY (LBS./KG) 740/335.6
LIGHTING FRONT White LED, High/Low
LIGHTING REAR LED, Tail – Brake
ADJUSTABLE STEERING Tilt Steering Wheel
ELECTRONIC POWER STEERING Yes
INSTRUMENTATION Digital Gauge, Analog Speedometer, Odometer,
Tachometer, Trip meter, Gear Indicator, Fuel Gauge,
AWD Indicator, Hi-Temp/Low-Batt Lights, DC Outlet
Описание тут,- правда на инглише :
http://www.arcticcat.com/prowler/wildcat.php?sub=good
http://news.utvguide.net/search/label/ARCTIC CAT WILDCAT 1000i H.O.
